I am having a problem with my computer, and the blue screen error code from Microsoft is IRQL_NOT_LESS_OR_EQUAL. I have tried upgrading my graphics card/AMD driver, updating the WIFI driver, replacing the SSD, and running RAM tests without any issues. However, even after reinstalling the operating system, the blue screen error still persists. Here are some of the different error messages I have encountered. Could you please help me take a look at them? Thank you.
dump file 1
dump file 2
dump file 3
dump file 4
dump file 1
dump file 2
dump file 3
dump file 4
Code:
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: fffffffffa838904, memory referenced
Arg2: 00000000000000ff, IRQL
Arg3: 0000000000000000, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff80009e74e10, address which referenced memory
Debugging Details:
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 2093
Key : Analysis.DebugAnalysisManager
Value: Create
Key : Analysis.Elapsed.mSec
Value: 57155
Key : Analysis.IO.Other.Mb
Value: 0
Key : Analysis.IO.Read.Mb
Value: 0
Key : Analysis.IO.Write.Mb
Value: 0
Key : Analysis.Init.CPU.mSec
Value: 202
Key : Analysis.Init.Elapsed.mSec
Value: 14162
Key : Analysis.Memory.CommitPeak.Mb
Value: 87
Key : Bugcheck.Code.DumpHeader
Value: 0xa
Key : Bugcheck.Code.Register
Value: 0xa
Key : WER.OS.Branch
Value: ni_release
Key : WER.OS.Timestamp
Value: 2022-05-06T12:50:00Z
Key : WER.OS.Version
Value: 10.0.22621.1
FILE_IN_CAB: 022423-9328-01.dmp
BUGCHECK_CODE: a
BUGCHECK_P1: fffffffffa838904
BUGCHECK_P2: ff
BUGCHECK_P3: 0
BUGCHECK_P4: fffff80009e74e10
READ_ADDRESS: fffff8000a91c468: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
unable to get nt!MmSpecialPagesInUse
fffffffffa838904
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
TRAP_FRAME: ffffba80c6dd3180 -- (.trap 0xffffba80c6dd3180)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=fffffffffffffff8 rbx=0000000000000000 rcx=0000000000000000
rdx=fffff80009c00000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80009e74e10 rsp=ffffba80c6dd3318 rbp=fffff800066e3180
r8=ffffba80c6dd37e0 r9=ffffba80c6dd37e0 r10=0000000000000000
r11=0000000000000000 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up di pl nz na pe nc
nt!KiSearchForNewThreadOnSubNode:
fffff800`09e74e10 48895c2410 mov qword ptr [rsp+10h],rbx ss:0018:ffffba80`c6dd3328=0000000000000000
Resetting default scope
STACK_TEXT:
ffffba80`c6dd3038 fffff800`0a033fa9 : 00000000`0000000a ffffffff`fa838904 00000000`000000ff 00000000`00000000 : nt!KeBugCheckEx
ffffba80`c6dd3040 fffff800`0a02fee8 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiBugCheckDispatch+0x69
ffffba80`c6dd3180 fffff800`09e74e10 : ffffba80`c6dd3620 ffffaa80`2bfe3180 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x468
ffffba80`c6dd3318 ffffba80`c6dd3620 : ffffaa80`2bfe3180 00000000`00000000 00000000`00000000 fffff800`0a94c6c0 : nt!KiSearchForNewThreadOnSubNode
ffffba80`c6dd3320 ffffaa80`2bfe3180 : 00000000`00000000 00000000`00000000 fffff800`0a94c6c0 fffff800`066e3180 : 0xffffba80`c6dd3620
ffffba80`c6dd3328 00000000`00000000 : 00000000`00000000 fffff800`0a94c6c0 fffff800`066e3180 00000000`00000000 : 0xffffaa80`2bfe3180
SYMBOL_NAME: nt!KiSearchForNewThreadOnSubNode+0
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
IMAGE_VERSION: 10.0.22621.525
STACK_COMMAND: .cxr; .ecxr ; kb
BUCKET_ID_FUNC_OFFSET: 0
FAILURE_BUCKET_ID: AV_nt!KiSearchForNewThreadOnSubNode
OS_VERSION: 10.0.22621.1
BUILDLAB_STR: ni_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {34c9066a-6b1d-6254-2bf5-5d8feebcea65}
Followup: MachineOwner
Code:
Arguments:
Arg1: 0000000000000001, memory referenced
Arg2: 0000000000000002, IRQL
Arg4: fffff80077a1eb0a, address which referenced memory
Debugging Details:
Value: 2405
Value: Create
Value: 18088
Value: 0
Value: 0
Value: 0
Value: 202
Value: 9146
Value: 98
Value: 0xa
Value: 0xa
Key : WER.OS.Branch
Value: ni_release
Value: 10.0.22621.1
FILE_IN_CAB: 022523-11812-01.dmp
BUGCHECK_CODE: a
BUGCHECK_P1: 1
BUGCHECK_P2: 2
BUGCHECK_P3: 0
BUGCHECK_P4: fffff80077a1eb0a
READ_ADDRESS: fffff8007851c468: Unable to get MiVisibleState
0000000000000001
BLACKBOXWINLOGON: 1
PROCESS_NAME: explorer.exe
TRAP_FRAME: ffffb1061b740a90 -- (.trap 0xffffb1061b740a90)
rax=00000000000001e1 rbx=0000000000000000 rcx=0000000000000001
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80077a1eb0a rsp=ffffb1061b740c20 rbp=ffffb1061b740d90
r8=0000000000000000 r9=ffffb1061b740fc0 r10=0000000000000000
iopl=0 nv up ei ng nz na pe nc
nt!KiSearchForNewThreadOnProcessor+0x8ba:
fffff800`77a1eb0a 6833d2e81e push 1EE8D233h
MISALIGNED_IP:
nt!KiSearchForNewThreadOnProcessor+8ba
STACK_TEXT:
ffffb106`1b740948 fffff800`77c3e2a9 : 00000000`0000000a 00000000`00000001 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
ffffb106`1b740950 fffff800`77c39934 : 00000000`00000000 00000000`00000000 00000000`00000001 00000400`00000000 : nt!KiBugCheckDispatch+0x69
ffffb106`1b740a90 fffff800`77a1eb0a : ffffb106`00000002 ffffa10a`00000000 00000000`00000000 00000000`0000000c : nt!KiPageFault+0x474
ffffb106`1b740c20 00000000`00000000 : 00000000`00000000 00000000`00000000 ffff4df4`ed093d22 00000000`00000000 : nt!KiSearchForNewThreadOnProcessor+0x8ba
SYMBOL_NAME: nt!KiSearchForNewThreadOnProcessor+8ba
IMAGE_VERSION: 10.0.22621.1265
MODULE_NAME: AuthenticAMD
IMAGE_NAME: AuthenticAMD.sys
FAILURE_BUCKET_ID: IP_MISALIGNED_AuthenticAMD.sys
OSNAME: Windows 10
FAILURE_ID_HASH: {716d112a-8330-4bbb-160c-ec98297019d2}
