IRQL_NOT_LESS_OR_EQUAL RAM issue
Thacker_96
17
I recently built my new computer and used my RAM from my old computer into my new one.
I put 4 GB DDR3 RAM and it works fine, no errors but when i put both in (8GB in total) it blue screens my computer and gives me the IRQL_NOT_LESS_OR_EQUAL error.
I wanted to know is it an driver/program issue which is causing the 8GB causing it to crash or is it the other RAM stick.
Both of the sticks worked fine in my other computer but since i've upgraded i've had issues.
I have quickly done a Memory Test (Windows) and it came back with no errors.
Please note: It only blue screens when i put the other RAM stick in.
My PC Specs -
- M5A78L-M/USB3
- AMD FX-6300
- 4GB RAM (Trying to use 8GB)
- Nvidia GTX 750ti FTW
- 400W Power Supply
- Zalman Z11 Plus
- 1.5TB HDD
I would think that a stick of ram is bad. Try running memtest86 on the old ones and if you see any red text, then you got a bad stick of RAM on your hands. You may also have a bad RAM slot, but I would think that the RAM is bad before that.
Thank you for your reply. As I stated, I have already tested it. Any other solutions?
For around 2 hours.
