Is 144 hz monitor worth it (BenQ XL2411Z - 144 Hz)
iddleDOTA
My pc stuff -
Video -Nvidia GeForce GT 640 OEM 4096mb (4Gb) DDR3
CPU - Intel(R) core(TM) i3-3220 CPU @ 3.30GHz
RAM - 8 GB
I want to play CSGO as well , im playing at 1024x768 resolution and i have up to 200 fps.
Tried 16:9 and 1280x1024 (max) and all on high/very high and i had 120 fps mostly
I've heard if u have monitor like that u have to play in max res (1920x1080) and do you think ill get enough fps with it? Explain a little bit to me why i should buy this.
Cheers.
Yes, worth it, if you can actually see 120 fps, if not, don't buy it, it will kinda ruin your experience.
@KnowledgeCore in some corners on the map i can get 190-220 ,mostly 120 and sometimes about 80-90 and i smoke lower thats in max resolution and everything on very high and high.
Then yes, you should get one, deifinitely.
I'm pretty sure you can still use 144hz without playing on it's native res, I believe I just read this the other day. Not sure if it's true or not.
The difference between a 60hz monitor and a 144hz monitor is night and day. I've only heard good things about getting one.
