Is 2 vram enough for my monitor?
unity
26
hi, I am wondering if 2vram is enough for my Asus VG248QE game monitor and if 2vram is enough for max settings on games like bf4.
Monitor specs:
Fullhd 1920x1080p
144Hz
In general, it's fine, but you would need closer to 3-4GB to max out BF4. My buddy has SLi 2GB GTX 680's, and anything above medium prompts a crash and a DirectX memory error. However, it is likely more than VRAM contributing to his issue, as he is also running out of system memory. In your case, you might be able to max it out, but likely not at a constant 60FPS.
On youtube the game runs around the 30 to 60 fps with the gpu (msi gtx 770 lightning ) I choosed so I think with 2 vram I should be fine. thanks for the responds! :)
Sounds about right. You should grab a constant 60FPS with Antialiasing Deferred set to 2X, Antialiasing Post to Medium, and Ambient Occlusion to SSAO or even better, turn it off altogether. Also, lowering the mesh quality can help out if you have a weaker CPU.
