[SOLVED] Is 26 dBA loud for a case fan?
26db isn't "terrible", but I can tell you that those AF120 fans do not actually have a maximum 26db at full speed. They are louder than they would like you to believe however they are still better than a lot of fans out there for the price.
Those AF120 three pack fans are three pin models however, and that board does not have the ability to run 3 pin DC controlled fans off of it's PWM system fan headers so you will either need a case integrated or aftermarket fan hub that is capable of handling those three pin DC fans while connecting to a motherboard PWM header, or an aftermarket controller like the NZXT Grid v3. Phanteks has a couple of pretty good controllers as well.
Honestly, you'd be better off simply buying PWM fans to start...
Honestly, you'd be better off simply buying PWM fans to start with, to eliminate the issue entirely.
Reactions: RodroX
