T TomTomson11 Commendable Feb 15, 2016 25 0 1,530 Mar 3, 2016 #1 will a s12IIB 430w psu be enough fir a R7 370 paired with an x4 860k? And also which r7 370 would be better? A gigabyte one for 148 euros or msi gaming one for 156 euros? Thanks.
Solution bignastyid Mar 3, 2016 430w is enough for that setup, and the Seasonic S12II is a good quality unit. Either card should be fine.
dualcoreduron Reputable Feb 12, 2016 77 0 4,660 Mar 3, 2016 #2 I would recommend investing in a higher quality, higher wattage PSU. 430 is a little too close to the edge. Upvote -1 Downvote
Amdlova Distinguished Jun 7, 2013 1,993 551 20,890 Mar 3, 2016 #3 yes i use an 430 evga with the 4770k OC and a old 4870 oc. will be fine =) Upvote 1 Downvote
bignastyid Titan Moderator Jun 19, 2011 33,641 1,672 159,590 Mar 3, 2016 Solution #4 430w is enough for that setup, and the Seasonic S12II is a good quality unit. Either card should be fine. Upvote 1 Downvote Solution
