Phoenix864 :
Also, higher wattage PSUs are generally higher quality.
No. A generalized statement like that has zero support and is not true.
Phoenix864 :
PSUs generally last a long time, so it's better to go with more wattage for upgradability in the future.
Everyone always says this, but let's look at the facts. For the past many years now, power consumption is decreasing with each iteration of new hardware. So why would anybody need to future-proof? It's more of a good excuse to get a high-wattage power supply than an actually smart thing to do. Looking statistically, only a puny portion of people run multiple GPUs; and a 450W power supply could easily power two GTX 1060s anyway (not that the GTX 1060 supports SLI to begin with); a 450W power supply coiuld actually work fine with two GTX 1080 FE cards that are not overclocked along with a non-overclocked CPU.
GameFreak01048 :
Phoenix864 :
That's why I have a Corsair Platinum HX850i running a i5 4690K OC, GTX 960 OC, MSI Z97 PC Mate and 2 1 TB HDD's...
completely overkill but still...future-proofing!
That also means increased waste heat due to reduced efficiency compared to, say, a 450W power supply running those same specs. Increased waste heat reduces the lifespan of capacitors. Not that in your case in matters, but you literally spent money you didn't need to spend, when in the end you could have just gotten a better GPU.
