I just got a new PSU and GPU. On my older PSU and GPU, when idle, the TMP1 value would be at 43C, but now with the new GPU and PSU, the TMP1 idle value is 49C.
Is this verging on the dangerous?
Old idle value: http://imgur.com/yubBUFD (look at the MIN tab for my idle temp)
New idle value: http://imgur.com/I2lYXK5 (look at the VALUE tab for my idle temp)
As can be seen, not much difference in my CPU temps or fan speed (FANIN1).
Also, my motherboard temps are all similar values, except for TMPIN1 which is 4C higher. I believe TMPIN2 is a sensor for the CPU temps on the motherboard, because they both correlate.
The TMPIN1 temperature seems to be the issue here, because it can get very much higher when under gaming load compared to before. Any idea what TMPIN1 could refer to? If I can find out what motherboard sensor is this, I could try finding a solution.
Also, look at the FANIN2 idle value. From 1100RPM to 1500RPM. Why such a big jump? Can I regulate this in any way? (I think it is the case fan, this reaches 2100RPM when max load gaming, compared to 1600RPM with my 750 SC)
All of this is new for me, so I would appreciate guidance from the more knowing members of this forum.
