is 4K 60 FPS on Max settings still a pipe dream? or can you build a PC for 4K 60fps now?
abulkasam
is 4K 60 FPS on Max settings still a pipe dream? or can you build a PC for 4K 60fps now? Can you build a PC for me?
Thinking ahead to Star Wars Battlefront at 4K 60fps as the benchmark.
The biggest limitation right now for mid range GPUS and not Titans is the low VRAM allocation, and the fact that SLI doesn't properly increase VRAM but instead doubles the usage... but DX11 will fix that by allowing you to split the VRAM on both cards. That will be a significant performance boost when it comes out.
Here is my system to run Grand THeft Auto V at 60fps on HIGH-VERY settings http://pcpartpicker.com/p/78Xqyc
Is it worth? It's all on how you value the dollar. For me I have no interest in going to clubs or vacations, I love video games. It is my main hobby, and I worked hard to get my income at 21 without college.
http://1drv.ms/1E33GEU
But I will be perfectly honest with you, with a 4k TV like the SOny BRavia...
you can, but it cost a fuuuuuck ton of money, for example 3 GTX Titan X's
But I will be perfectly honest with you, with a 4k TV like the SOny BRavia Xbr65x850B you can actually upscale 1080p and it's pretty damn impresive.
Take a look:
http://1drv.ms/1GhZz6f
(Please note that these were taken with an iPhone, which "features" an auto exposure I can't turn off. So they may look different in color, but in real life they do not.)
THe first image is native 4k resolution. It's really clear, but suffers from small interface which is a common problem in video games without 4k scaling. THe second Image is Native 1080p without any enhancements from the TV other than edge smoothing.
The final image is 1080p use X Reality Pro to analyze the low resolutions on the screen and replace them with artificial similar textures, making things appear significantly higher in resolution. This is available on non 4k TVs as well, so if you really want a graphics update thats cheap with no performance cost, just get a good TV with upscaling features. To be honest with you, some video games look better with the fake upscaling than they do in 4k, and it works in gaming mode too so there's no increased lag.
Perhaps it does, but I'm such a Nvidia Fanboy. AMD would have to come out with something beneficial to me, like better 3D support. I always see issues with people running games on AMD cards, at least in MMO's.
AMD needs to come out with a card that only works on AMD motherboards, at the advantage it is cheaper and more performance, then I might consider.
Okay, but we are talking about 4k(amd does very well at 4k) not 3D and as far as i'm concerned 3D is a gimmick now that VR is becoming more of a reality. I don't play mmo's but as far as I know it's AMD cpu's that have a hard time not their gpus, correct me if i'm wrong.
I don't understand why AMD gpu's that only work on AMD mobo's is a good idea and why that would make you consider them? I try not to be a fanboy but I am not a fan of nvidia but I can admit when there cards are better in certain situations and at 4k AMD does very well in price to performance vs nvidia.
3d will not be a gimmick in the future, the future of gaming is virtual reality. And it will work with one left image, and one right image (per eye). So you're going to see it come back, just like how everyone thought virtual reality was a gimmick 20 years ago.
What I was saying is, the only way I can see AMD take over is if they develop a technology that only works on their motherboards, and sell it for cheaper than it costs to make assuming they will make slight royalties from the motherboard itself.
