Is 550w PSU is enough for x99 system?
kabir45
6
In our local stores they only have a maximum 550w ( http://www.thermaltake.com/products-model.aspx?id=C_00002408 ) PSU. They are saying 450w is enough for this system. But I'm confused. I need your expertise. Thank you.
This is the configuration.
http://pcpartpicker.com/p/cyBw4D
Intel Core i7-5820K 3.3GHz 6-Core Processor
Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
MSI X99S SLI Plus ATX LGA2011-3 Motherboard
G.Skill Ripjaws Series 32GB (4 x 8GB) DDR4-2400 Memory
Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive
Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
EVGA GeForce GTX 750 Ti 2GB Superclocked Video Card
Thermaltake Litepower 550W Power Supply
Samsung SH-224DB/BEBE DVD/CD Writer
That is a 'mini-van' PSU for a 'race-car' system, I would want something more high-performance. However, your CPU, even if overclocked, should not exceed 200W and the rest of your system will use no more than 150W, closer to 100. Exactly which EVGA 750 do you have? 3751, 53, 57, or 59?
So you could run that system on a good 450W PSU. 550W is plenty. If XFX is available locally, the 550W TS is a very good choice, or the Seasonic SS12II 520W. If you have questions, post a link to a site you might buy from so we can see what you have available.
Thank you.
So is this Thermaltake Litepower 550W Power Supply will good enough for this system?
