I have a Corsair Carbide 300R; it can support 7 fans:
- 2xFront, Top, Side
- 1xRear
All but Rear can be 140mm.
Normal load temps (with some slight OC) never exceed 70c, but I prefer cooler especially as I am soon to upgrade components.
I currently only have 1x120mm in Front and Rear. My current plan is to install:
- 2x140mm Front, Side and Top (1200-1400RPM)
- 1x120mm Rear (1400RPM)
Front and Side are intake, Top and Rear exhaust, this is 4:3 so slightly positive in terms of pressure (I clean frequently so dust isnt really an issue).
All that said, there comes a point of diminishing returns where the temp isnt going to really change drastically, or maybe even +/- a couple of degrees.
But are there any negatives to having all the fan spots filled?
I've read the following in trying to solidify my plan:
- No such thing as too many fans
- Positive is better than Negative (since I clean a lot I will negate anyhow)
- If you have a spot that can fit a 140mm, use 140mm not 120mm
- 140mm is better than 120mm (slower yes, but more air and quieter)
Interested in all arguments!
Cheers!
- 1xRear
Cheers!
