P PixelBlade Honorable Dec 22, 2013 61 0 10,630 Mar 21, 2015 #1 While playing Battlefield Hardline on high my Gpu goes to about 72 degrees Celsius is that too hot for full load? My Gpu Is a MSI R9 280x. This is the only game that makes it run that hot.
bignastyid Titan Moderator Jun 19, 2011 33,689 1,700 159,590 Mar 21, 2015 Solution #2 72°C is fine for full load. Upvote 0 Downvote Solution
P PixelBlade Honorable Dec 22, 2013 61 0 10,630 Mar 21, 2015 #3 bignastyid : 72°C is fine for full load. Thank you, is it fine if I play for a long time as well? Upvote 0 Downvote
bignastyid Titan Moderator Jun 19, 2011 33,689 1,700 159,590 Mar 21, 2015 #4 PixelBlade : bignastyid : 72°C is fine for full load. Thank you, is it fine if I play for a long time as well? Yes. Most cards don't even throttling down for self preservation till 90+. Upvote 0 Downvote
P PixelBlade Honorable Dec 22, 2013 61 0 10,630 Mar 21, 2015 #5 bignastyid : PixelBlade : bignastyid : 72°C is fine for full load. Thank you, is it fine if I play for a long time as well? Yes. Most cards don't even throttling down for self preservation till 90+. Ok, well this is solved thanks for you help and time. Upvote 0 Downvote
