B berryzakir Prominent Jan 28, 2018 9 0 510 Jan 28, 2018 #1 Im planning to built a pc with i7 7700k and gtx 980 with 700w is it enough to power it?
Solution COLGeek Jan 28, 2018 berryzakir : Its an aerocool gt 700w It should be okay. Good luck with the new build.
COLGeek Cybernaut Moderator Apr 6, 2009 57,763 4,556 179,340 Jan 28, 2018 #2 Yes, 700w is enough if it is a quality PSU that actually produces the power it claims. What make/model PSU do you intend to use? Upvote 0 Downvote
B berryzakir Prominent Jan 28, 2018 9 0 510 Jan 28, 2018 #3 COLGeek : Yes, 700w is enough if it is a quality PSU that actually produces the power it claims. What make/model PSU do you intend to use? Upvote 0 Downvote
B berryzakir Prominent Jan 28, 2018 9 0 510 Jan 28, 2018 #4 Its an aerocool gt 700w Upvote 0 Downvote
COLGeek Cybernaut Moderator Apr 6, 2009 57,763 4,556 179,340 Jan 28, 2018 Solution #5 berryzakir : Its an aerocool gt 700w It should be okay. Good luck with the new build. Upvote 0 Downvote Solution
B berryzakir Prominent Jan 28, 2018 9 0 510 Jan 28, 2018 #6 COLGeek : berryzakir : Its an aerocool gt 700w It should be okay. Good luck with the new build. Upvote 0 Downvote
B berryzakir Prominent Jan 28, 2018 9 0 510 Jan 28, 2018 #7 Thank you very much for your help Upvote 0 Downvote
COLGeek Cybernaut Moderator Apr 6, 2009 57,763 4,556 179,340 Jan 28, 2018 #8 You are most welcome. Cheers. Upvote 0 Downvote
B berryzakir Prominent Jan 28, 2018 9 0 510 Jan 28, 2018 #9 COLGeek : You are most welcome. Cheers. Upvote 0 Downvote
S Spank1 Honorable Nov 27, 2013 21 0 10,520 Feb 1, 2018 #11 Wouldn't be my first choice of PSU, I'd go with Corsair or another big name brand. My Corsair came with a 10 year guarantee. Upvote 0 Downvote
B berryzakir Prominent Jan 28, 2018 9 0 510 Feb 1, 2018 #12 Spank1 : Wouldn't be my first choice of PSU, I'd go with Corsair or another big name brand. My Corsair came with a 10 year guarantee. Upvote 0 Downvote
