[SOLVED] is 84c too hot for GTX 1060 3gb Zotac?
Eximo
Herald
Yes, the typical throttle point on the 10 series is 83C, so it is hitting its top end. The GPU itself is good to 100 or 105C. Nvidia limits it so the clock speeds can stay relatively high.
You can see if you can increase fan speed to get it a little cooler. Or increase airflow to the chassis to try and get the heat out.
Eximo
Herald
