Hello everyone, I have an old Asus ROG G53Sw and I wanted to ask you if I should be worried about its GPU temperature.
Is GTX 460M supposed to heat up to 94 degrees under 100% load? When idle its temperature is usually less than 65 degrees. It doesn't throttle, shut down or anything, I'm just worried because 94°C is pretty hot.
Thanks in advance and sorry for any grammar mistakes.
