LeviTech Commendable Sep 27, 2021 281 21 1,715 Jan 8, 2022 #2 9600k its a worse choice because it misses MT, some instructions, higher TDP and a lower cache Upvote 0 Downvote
S sizzling Titan Oct 18, 2006 27,224 3,268 112,240 Jan 8, 2022 #3 It would likely depend if what you are doing can use more than 6 threads of the 9600k Upvote 0 Downvote
M Mr.Spock Admirable Dec 8, 2019 1,290 160 6,090 Jan 10, 2022 #4 also would depend on the OC you plan for the 9600K and whether you get any benefits from MT. The ability to OC may result in way better per core performance also factor not having iGPU on the latter chip and motherboard upgrade costs Last edited: Jan 10, 2022 Upvote 0 Downvote
M mdd1963 Titan Jan 14, 2006 16,614 1,729 81,240 Jan 11, 2022 #5 Either had best be at fire-sale prices given current i5-12400/12400F pricing... Upvote 0 Downvote
