Kdog61377 :
S4STINDUBZ :
My apologies I was confused on what you were suggesting. A little tired. For G sync with 144hz, that's your best price point for sure. However if you have some extra coin, you could go with 1440p/G sync/144hz:
ASUS ROG SWIFT PG278Q:
http://www.amazon.com/Asus-PG278Q-27-Inch-G-SYNC-Monitor/dp/B00MSOND8C
If not, between 1440p and G sync/144hz, it come down to personal preference, whether you prefer smoother or better looking gameplay.
Trust me I've looked at that monitor and I truly want it I might save money for it I just didn't know how well/badly my card would have performed on 1440p and I am afraid it would kill my gpu in games because I'm not one to enjoy 30 fps unless it's potato optimized Dayz. Do you think it is worth to wait for the ROG swift or better to get a monitor I know I can have good performance with... even thought the Swift is amazing.
Have you tried looking into acer ?
Acer Predator XB271HU bmiprz 27-inch WQHD (2560 x 1440) NVIDIA G-Sync Widescreen Display
This monitor have the same spec as the ASUS ROG SWIFT PG279Q
or maybe look at this one for a cheaper option
Acer XB270HU bprz 27-inch WQHD NVIDIA G-SYNC (2560 x 1440) Widescreen Monitor
The only difference between the XB270HU and XB271HU is that the 271 has the potential to OC to 165Hz refresh rate
Both of these monitors are IPS and has 4ms reponse time and also G-Sync
