Is a 300W Enermax PS enough for my system?
bastardman
64
I'm upgrading a system for my friend. Here is what I've got;
Asus A7M266
1700+ Athlon XP
256MB PC2100
Diamond Speedstar POS video (didn't get upgraded)
On-Board sound
20GB 5400 Harddrive (didn't get upgraded)
12x10x24 CDR
300Watt Enermax PS
Will the Powersupply be sufficient?
Twitch
1,466
Yup. If you had a generic power supply, maybe it would be an issue, but that Enermax should be great.
I want to move to space, so I can overclock processors cooled to absolute zero.
LumberJack
655
I have a similar system and I use a 350w. You can get away with 300 but if you want to add lots of peripherals like me... or upgrade frequently I would go with a 350.
To err is human... to really screw things up you need a computer!
Teq
1,519
Should be...
I have an XP1800+ (Palamino) in mine with cd-rw, cd, maxtor, nvidia, and the usual array of fans and such. All running off a 300 watt supply, it's stable as a rock.
<b>(</b>It ain't better if it don't work.<b>)</b>
svol
Champion
Jul 18, 2001
16,619
With that setup 300W will be plenty.
But if you plan to add a new videocard and more HDs/fans/CDROMs then you might want to go for 350W.
My dual-PSU PC is so powerfull that the neighbourhood dims when I turn it on :eek:
Similar threads
