Is a 300W power supply enough?
donsauce
13
Hi, I recently have been getting into more demanding gaming. So i thought it would be time for a upgrade on my Graphics card, my current card is a GTX 750ti. I was looking on getting, EVGA GeForce GTX 1060 SC GAMING, (https://www.newegg.ca/Product/Product.aspx?item=N82E16814487261)
I only have a 300w power supply and I have been searching online if it is a enough and I have seen different answers.
Specs:
MotherBoard - https://gyazo.com/fa630002e6b41a29cf26fba9d554711a
CPU - Intel Core i5 2320
Power supply - FSP300-60EP(1)
Graphics card - GTX 750ti
I was thinking about bringing the pc to the guy who built it to ask him but thought I might be able to ask here.
Well, I get payed next week, so my budget could be anywhere around 600$
Well dang with that budget you could get a new CPU/Mobo/RAM setup.
If you just wanted to upgrade GPU and PSU, get the GPU you mentioned and for a moderately priced PSU one of these would be good https://pcpartpicker.com/products/compare/TgW9TW,Tc3RsY,3F2rxr/
I was looking at the Corsair PSU, My only concern was I wasnt sure if it had the right pin connections for the 1060, Do you know if it does?
Yes it does. The GTX 1060 SC only require a sinlge 6-pin PCIE connector. The Corsair CX650 has 2x6+2-pin connectors. So you would simply use one of the 6+2 pin connectors. The +2 will just be hanging off to the side when the 6-pin is plugged in. That's just the way it works.
Alrighty man, thank you I'm going to pull the trigger on the Corsair after a little bit more research, i think thats the one for me at the price.0
Good question. What case do you have?
Also, I would prefer the SeaSonic 520W because it is fully modular, is slightly better quality, and is cheaper if you order on SuperBiz with the Halloween promo code. (as long as shipping isn't higher than what it showed me). But either would be just fine.
I am not sure of the case to be honest, the only thing I really know is it is the case in the Acer Veriton M4610G. here is a build with the same case https://www.mwave.com.au/product/acer-veriton-m4610g-desktop-pc-intel-core-i52300-28gh-aa86140#detailTabs=tabOverview
You know what I'm not sure why I even asked because the power supply you have now is the same size, standard 24-pin ATX power supply. It will fit.
*The fully modular will have less cables in the way is why they are better. Non-modular has all cables connected to the PSU, a lot of which won't be used. Fully modular means you only connect the ones you use. So if you don't want extra cables stuffed inside your case, get a fully modular. If you don't mind then don't worry.
Okay, last question will it matter which way the fan on the PSU is located? or as long as air gets to it it will be fine
I have a top mounted PSU Slot and the air vents are in the back. I also have some holes in the left side of the case, opposite from thge mother board
M12II and S12II are the same unit, just one is fully modular the other is just semi modular.
I ended up getting the Corsair. did some research and thought that was my best bet. Thank you for the help guys 😀
