Question Is a 305 power suply enough for an intel core 2 duo e6850 and a gt 710?
Feb 1, 2020
14
Hello
I want to upgrade my desktop dell optiplex 755
i want to upgrade the gpu to a 710 or anything that can work on a 305 watt psu(i have gma 3100)
i want to upgrade my ram from 2gb to 4gb
sorry if the description is messy english is my second language
delaro
Splendid
Ambassador
no ,its the mid tower version
The motherboard uses an ODD CPU placement that limits your GPU options to Single-slot and a length limit of around 11 inches "Interference with the 20+4 pin connector". You can replace the PSU with anything on the market should you want a little more muscle provided you max the CPU out "Q6600/Q6700".
710/730/740/750 TI/1030/1050/1050 TI/RX 460* all have single slot options and a reasonable to pair on OEM LGA775.
* requires a PSU upgrade
Reactions: GabrielTheNoob
Feb 1, 2020
14
i have to upgrade my psu to add the gpu and more ram or its only needed if i want to upgrade the cpu?
delaro
Splendid
Ambassador
I intended to answer that above but it seems the forum doesn't like the formatting and removed it. 😕
You can upgrade the CPU to the max Q6600/6700 without replacing the power supply.
You can add these GPU's with a CPU upgrade without replacing the power supply.
710/730/1030 " With a BIOS update"
Upgrades beyond that would require you to do so.
Feb 1, 2020
14
sorry for late reply
wil this one fit?
edit:can you tell me where i can find a the bios update for it if i need it
