[SOLVED] Is a 450W PSU enought for i5 and GTX 1660?
Jhonan
17
I'm looking to build a small/slim pc, and the case I have choosen (Fractal Design Node 202) can be bought with an included 450W PSU.
I wanna know if it can power an i5 (or a Ryzen 5) and a GTX 1660. One guy on newegg said he had done this with no problems (most other choosed a GTX 1070 and Ryzen 5, thought).
If it turns out I can't, how should I search for other slim PSU? Would be easier going with a less power hungry GPU/CPU?
Hey jhonan,
its quite confusing what a system needs however someone made a useful chart that we use on the forum: http://www.realhardtechx.com/index_archivos/Page362.htm
a good powersupply would be what matt sais else I like:
Power Supply: Corsair - SF 450 W 80+ Gold Certified Fully-Modular SFX Power Supply ($73.89 @ OutletPC)
Total: $73.89
Generated by PCPartPicker 2019-03-22 04:53 EDT-0400
if you want to get a better gpu in the future,
Power Supply: Corsair - SF 600 W 80+ Gold Certified...
Less power hungry??
You're talking a sub 100w cpu & a 120-130 gpu.
Efficiency wise there's nothing that touches them on performance.
The integra 450sfx psu included with the node is absolutely fine for that combination, there's no issue here at all.
I had trouble finding the gpu wattage, thanks.
Im a bit reluctant since it calls for a 600W PSU in logicalincrements for those two, do you know why?
Thanks for the help.
Hey jhonan,
Total: $73.89
Power Supply: Corsair - SF 600 W 80+ Gold Certified Fully-Modular SFX Power Supply ($99.89 @ OutletPC)
Total: $99.89
Generated by PCPartPicker 2019-03-22 04:54 EDT-0400
To sum it up for you, it doesnt matter if you get a 600w or a 450w psu, your system wont run better or longer from it.
Reactions: Jhonan
