[SOLVED] Is a audio interface good enough for 30 ohm headphones?
Hi, i'm using a BDP-S350 blu-ray player, and the volume via the headphone is quite low, i was thinking to boost it, i'd use a headphone amplifier, however since my headphones are only 30 ohm, a audio interface may suffice, what do you guys think ?
this is the audio interface - https://djcity.com.au/product/behringer-um2-audio-interface/
That is not the use of an audio interface, it connects to a computer with drivers through USB, it's not for just home theater devices. I would get a simpler cheaper headphone amp...
That is not the use of an audio interface, it connects to a computer with drivers through USB, it's not for just home theater devices. I would get a simpler cheaper headphone amp https://www.amazon.com/Headphone-Am...earch-10&pf_rd_t=BROWSE&pf_rd_i=13880161&th=1
https://www.amazon.com/Behringer-HA...sed-search-10&pf_rd_t=BROWSE&pf_rd_i=13880161
How are you connecting the headphones, that player does not have a headphone out. Through the TV headphone out? Or is it a line out?
Blu ray player > RCA to 3.5mm > 6.3mm adapter.
Also i'm thinking of getting this amplifier, what do you think ?
https://djcity.com.au/product/ld-systems-hpa4-4-channel-headphone-amplifier/
For the record, I run an Audient iD4 with 32-ohm Sennheiser HD439s hanging off them, and the iD4's hardware has absolutely no problem driving them. YMMV though, depending on which interface / combo you plan on getting.
From what I can read, there isn't mentioned a head phone outlet. It may or it may not work, but in general you should look for a product that have an actual head phone outlet.
I had a UM2--they only have a 6.3mm out.
