is a geforce gtx 750 capable of running games like fallout 4 and skyrim at full 60fps and smoothly
BinaryCoded
Commendable
Mar 10, 2016
I wanted to know if the geforce gtx 750 can run games like fallout 4 and skyrim with mods at 60 fps and smoothly.Whoever replies thankyou.
Skyrim is limited mostly by your CPU. If you have any modern (Haswell or newer) Core i3 or any second gen or better Core i5/i7, then you should be fine.
Fallout 4 is a bit more complicated, but you should get near 60fps on lower settings.
Note that this is all about the 750ti, since the vanilla 750 is no longer available.
The 750 also doesn't exist right now, since Nvidia replaced it with the 750ti. (used to be you could get either, but for the last few months that's not an option)
With very big letters in a red box saying that the item has been replaced by a new version.
Face it, nvidia has replaced the card in question, and it was never as big of a performance difference as you are trying to claim. Difference between 60fps and not on fallout 4 1080p? maybe in some settings, but it's not like one card gets 60fps while the other gets 30
lol just because there is a newer version doesn't mean the older version is suddenly non-existent.
If the OP is asking about a specific card, I don't think it's a good idea to assume a different card.
Anyway, the GTX750ti is not a replacement card for the GTX750 just as the GTX650ti was not a replacement for the GTX650.
Have they stopped making the GTX750? Yeah probably. The GTX950 was the official replacement.
