E Edvinas_6 Commendable Dec 10, 2016 4 0 1,510 Dec 10, 2016 #1 Will a gtx 1050 will be compatible with my specs. specs are : motherboard :Gigabyte Technology Co. Ltd. GA-MA770T-UD3 (Socket M2) Ram: 2x4gb Cpu: AMD Phenom X4 II 965 Thanks help.
Solution chemmajorp53 Dec 10, 2016 yes, as long as it fits in your case and you have a power supply that's preferably ~300W or higher
chemmajorp53 Dignified Apr 5, 2013 3,160 1 15,010 Dec 10, 2016 Solution #2 yes, as long as it fits in your case and you have a power supply that's preferably ~300W or higher Upvote 0 Downvote Solution
H henry28 Commendable Aug 28, 2016 215 0 1,710 Dec 10, 2016 #3 it will work as your mobo should have pci express Upvote 0 Downvote
