Is a GTX 950 enough for one 2560x1080p monitor?
How do you mean it won't be great? Will i see difference if i'd hook up a normal 27" 1080p screen?
Won't i be able to run low end games on the ultrawide screen?
There won't be a difference in image quality between most GPUs, where the difference lies is how fast a GPU can render those images aka frames per second. A 950, being on the bottom of the maxwell ladder will yield the lowest fps. I'll run diablo 2 no problem on that resolution, but will struggle with modern AAA titles.
