Is a half duplex ethernet cable different than a full duplex ethernet cable
Himanshu_26
6
Is a half duplex ethernet cable different than a full duplex ethernet cable???
If yes then how can I differentiate between them?
sorry they use a rj45 connector regardless full or 1/2
http://www.groundcontrol.com/galileo/ch5-ethernet.htm
thing is best I recall like gigabit ethernet is full duplex only like used on modern motherboards
wiring to be all the same as standard [its not the wire/cable its the device thart uses the cable as full or at 1/2 ]
''Transcript''
''As you can see here, the RJ45 connectors…in Ethernet networks have eight wires.…There are four pairs.…Now, half duplex unfortunately…does not have take advantage of all these pairs.…They only take advantage of one pair.…They can only send, or receive information…back and forth.…So what happens with that?…Not only can you only send or receive,…but you have half of the...
''Transcript''
''As you can see here, the RJ45 connectors…in Ethernet networks have eight wires.…There are four pairs.…Now, half duplex unfortunately…does not have take advantage of all these pairs.…They only take advantage of one pair.…They can only send, or receive information…back and forth.…So what happens with that?…Not only can you only send or receive,…but you have half of the bandwidth.… ''
https://www.lynda.com/CCENT-tutorials/Comparing-half-full-duplex-Ethernet/368762/408752-4.html#tab
