Is A Monitor Stand Worth It?
swoozm8
81
Hey, I saw some cool high-end setups and monitor stands look cool at those setups. Do you have a monitor stand? Would u rec me one?
Btw whats the best way to clean my monitor?
I have two monitors mounted with ergotron wall mounts.
I highly recommend that type of setup if you can.
One big advantage is more desk space.
ergotron is expensive, but the quality is truly there. Their web site has specs and options.
I never seem to have the need to clean my monitors.
A slightly damp cloth should do the job.
