Question Is a Router with Ethernet more secure than with wireless connection?
USAFRet
123,476
3,840
159,940
19,526
Most current routers have both.
But how your device connects to it is the key.
An ethernet cable is more secure, in that it cannot be sniffed between PC and the router.
But, a properly configured WiFi is pretty secure as well.
USAFRet
123,476
3,840
159,940
19,526
Then the router is not secure? or is it secure for the pc only?
Not sure what you're asking here.
"secure", in what context?
To access your router and the traffic going through it:
You need to be connected to it with an ethernet cable.
and/or
Within WiFi range, AND know the admin username/password, OR have a poorly configured router.
USAFRet
123,476
3,840
159,940
19,526
WPS - WiFi Protected Sharing. An attempt to make WiFi 'easier'. Resulted in a horribly broken password thing, that is not even a speed bump for someone that wants to break in.
Chinese characters? No. Your router may not speak Mandarin.
Seriously.
USAFRet
123,476
3,840
159,940
19,526
How do i know if WPS is activated on my router? i made many online router safety tests , are these reliable?
You look in the router settings.
You need to log into the actual router settings.
username and password.
This would be the username and password that YOU set up, rather than just leaving at the default.
Again, read that link I posted above.
USAFRet
123,476
3,840
159,940
19,526
What does it mean outside from lan?
I can not find my routers ip to enter the settings . Where can i find it?
For instance:
If you were at Starbucks, on their free WiFi, you could connect to your router and do all those administration things.
This is usually a bad idea.
It is almost always OFF by default.
You find that by logging into the router, and looking around.
username/password for the router, not for the WiFi. They are different.
tzuzu100
177
There is an option, it says DEACTIVATE SSID, but when i click on it it disconnects my connection.
But there is another option: Hide SSID from all Basestations
2,4 GHz-Basestation
and
2,4 GHz-Basestation.
I can not find DISABLE EXTERNAL ACCESS,
Where do I have to look for it?
