is a ryzen 5 2600 and gtx 1660 ti enough for 144hz?
May 9, 2019
i know if i wanna reach 144 fps i gotta lower the settings, but i need extra assurance that it will be able to play at 144 fps on games such as fortnite, apex, maybe even pubg or should i just get a 2060 and will it be far better then the 1660 ti or significantly better? thanks in advance pc;mr! (RAM:16GB*3000mhz)
also if you guys know any builds that can run 144hz with a budget of 900-1000$ please leave a suggestion thank you!
1080P?
If you overclock that 2600 and pair it with dual channel 3200mhz memory then 144hz should be achievable with the 1660 ti.
For $1000 this is what I'd get.
PCPartPicker Part List
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor ($164.39 @ OutletPC)
CPU Cooler: Cooler Master - Hyper 212 Black Edition 42 CFM CPU Cooler ($29.53 @ B&H)
Motherboard: ASRock - B450M Steel Legend Micro ATX AM4 Motherboard ($90.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory ($87.99 @ Newegg)
Storage: Intel - 660p Series 1 TB M.2-2280 Solid State Drive ($109.89 @ OutletPC)
Video Card: Zotac - GeForce RTX 2060 6 GB GAMING Video Card ($349.99 @ Newegg)
Case: Fractal Design - Focus G Mini (Black) MicroATX Mini Tower Case ($55.83 @ Newegg)
Power Supply: SeaSonic - FOCUS Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply ($61.98 @ Newegg)
Case Fan: be quiet! - Pure Wings 2 120 51.4 CFM 120 mm Fan ($10.39 @ OutletPC)
Total: $960.97
Generated by PCPartPicker 2019-05-09 12:23 EDT-0400
