Question Is a Ryzen 5 3600 going to pair well with 3600Mhz memory?
JaAntonio
Proper
Nov 13, 2019
116
23
115
11
Hi, 3600Mhz will the best speed to this CPU. As example i would say Ryzen 1000 series tend to 3000-3200Mhz with a bit of luck, 2000 Series the sweet spot is 3200Mhz and 3000 series the optimal is 3600Mhz.
Check the prices differences and if the money isn't a concern buy the 3600Mhz kit.
Jan 8, 2020
8
What is the fastest MHz that you're MOBO can have?
Would suck to buy that 3600MHz just realize that you're MOBO doesn't support that kind of speed.
But if the MOBO supports 3600 then go for 3600 CL 15 or 16.
Latest posts
