Question Is a Ryzen 7 2700 compatible with a Micro-ATX motherboard?
Dec 9, 2019
I just obtained a Ryzen 7 2700 and I was wondering since it has the tower like fan is it still compatible with a Micro-ATX motherboard (GIGABYTE B450M DS3H)?
Tower fan? Did you buy this used from someone? If the cooler is not the stock fan it may require an adapter to fit a different board than it was originally installed on. Also, it may not fit the case you intend to put it into. You need to provide more information. The Ryzen 7 2700 CPU itself is compatible with GIGABYTE B450M DS3H.
I am a fool and was thinking the Threadrippers Fan was the same for the Ryzen 7s. All I really wanted to know if the board and CPU were compatible.
