Hey folks!
My rig specs are in my signature. My onboard sound card is what I have for sound, but I'm looking for a li'l bit more! For eg, when I play Crysis 1 and Warhead, the volume is at full but the sound is very evry soft! It's only crysis that this happened with. All other games its ok.
So here's what I did. I unplugged the headphone jack from the mobo and plugged it into my Dell Monitor (in order to use the HD Audio of my GPU) and it worked! The sound was loud and better.
I've been considering getting a dedicated sound card....specifically the Asus Xonar DX.....as I'm under the constant belief that the sound card would not only remove the load from the cpu (now gpu), but will give that extra kick!
So, my simple question: will the addition of a sound card do the trick without my having to upgrade my headphones? I'm not looking at upgrading the headphones as of now.
Thanks again!
Thanks again!
