Rinshun Commendable Sep 19, 2020 24 2 1,535 Dec 20, 2022 #1 For just stock configuration. No OC. I know it comes with a Wraith Stealth, but I'm upgrading my 1600, which came with a Spire. I use a 6700XT (idk if it matters) and I have 2 fans for the case cooling. Last edited: Dec 20, 2022
Solution Darkbreeze Dec 20, 2022 The Spire is higher end than the Stealth, so yes, it not only is good enough but it's better than the one that it comes with.
Darkbreeze Retired Mod Jun 24, 2014 82,651 8,314 176,790 Dec 20, 2022 Solution #2 The Spire is higher end than the Stealth, so yes, it not only is good enough but it's better than the one that it comes with. Upvote 0 Downvote Solution
