I have an AMD 3950x installed on an ASUS Crosshair VIII Hero mobo - both residing inside an ASUS Helios case. No OC-ing done. The side panels are currently removed (waiting to finish the cable management). The temperature reads as 41 +/- 2 in idle mode. Isn't this a bit high with an AIO and an open case?
The reason I'm concerned a bit is that when I tried to install the AIO on the cpu, the coldplate glided somewhat (really poor latch-screw design !) .. Also please check the corsair link image below: Two temps register above 100!! which have gotten me both confused and concerned. Do you think I should repaste? Or the temps given the above situation is just normal?
EDIT: Could a moderator please move this post to the Cooling sub-forum. Maybe this post is better suited to that SF. Thank you.
