D Dralight Reputable Jun 30, 2015 16 0 4,510 Jul 2, 2015 #1 And will it be powerful enough? I have read that 650w is fine. I need a new PSU and i'm trying to find one that's the same size as my current one so it will fit in my case okay.
Solution Wolfshadw Jul 2, 2015 The graphics card requires one 6-pin and one 8-pin PCI-E power connectors from the power supply. The Antec TP-650 has two of each. You're good to go. -Wolf sends
migronesien Honorable Jun 3, 2015 1,270 3 11,965 Jul 2, 2015 #2 Yes, 650w is always enough for a single card. Upvote 0 Downvote
Wolfshadw Titan Moderator Aug 3, 2006 28,523 1,699 133,290 Jul 2, 2015 Solution #3 The graphics card requires one 6-pin and one 8-pin PCI-E power connectors from the power supply. The Antec TP-650 has two of each. You're good to go. -Wolf sends Upvote 0 Downvote Solution
D Dralight Reputable Jun 30, 2015 16 0 4,510 Jul 2, 2015 #4 Wolfshadw : The graphics card requires one 6-pin and one 8-pin PCI-E power connectors from the power supply. The Antec TP-650 has two of each. You're good to go. -Wolf sends Just what I needed to hear. Thanks! Upvote 0 Downvote
