Question is an i5 4690k cpu compatible with my ASRock 990FX Extreme3 ATX AM3+/AM3 Motherboard?
Paradox122
18
i have came upon an i5 4690k cpu and i am wondering if it will be compatible with my dinosaur of a motherboard
NO, the 990fx motherboards are only capable of supporting AM3 or AM3+ CPUs from AMD.
No Intel manufactured CPUs will work in that motherboard.
You could use an FX cpu in that motherboard, although the ASRock 990FX Extreme3 seems to be a very low-end 990FX board with only 4+1 phase VRM design not even capable of properly supporting a stock 8350. Keep in mind, some modern motherboards will have 8 or more VRM phases
I would recommend upgrading to a newer CPU, motherboard, and ram.
REF: https://forums.tomshardware.com/threads/help-amd-fx-8350-with-asrock-990fx-extreme3.2920305/
https://www.asrock.com/mb/AMD/990FX Extreme3/
Smh that mobo supports amd cpus what makes you think you can put an intel cpu in there it says am3 in the mobo name
u have a lot to learn
