Hello,
I am planning a build, but the configured chassis comes with an Intel 1600 watt power supply. Since the board is custom, this is the only power supply and chassis available.
I have been told by a custom computer builder that this particular power supply will be very loud. Note, I will not be utilizing all 1600 watts, and initially, about 700 watts, but I will be leaving this particular workstation to my alma mater when I die and they might utilize the entire 1600 watts.
Intel support told me that the PWM Offset can be set to 0 in the bios and that will significantly reduce the noise from the power supply.
Remember, this is the ONLY chassis system available for this particular board. Sadly, the particular Intel workstation chassis only comes with a 1600 Watt power supply.
I have looked at Super Micro, and their systems also come with 1200 watt or greater power supplies. Also, the accompanying Super Micro boards have a password vulnerability.
Anyhow, the builder kind of made it seem that the PSU will be uncomfortably loud in my living room. The Intel person said it would not likely be loud with that adjustment and the fact that I would not be operating at full load.
