Is an RTX 2080 way too much for a laptop?
You really need to try and find reviews of the specific laptop, however a 2080 does seem over the top for 1080p. I’m running a 9750h & 2060 with a 1080p 144Hz monitor and it’s an excellent setup. The only problem is the Intel cpu runs extremely hot, I had to undervolt and reduce the boost speeds to keep the cpu temperature at 80-85c. This is a common problem with Intel gaming laptops. It is becoming harder to undervolt as newer BIOS lock out this feature due to a security vulnerability. The 2060 actually runs very well, never goes over 80c.
Reactions: hepez
I think there is an error in the web site, a laptop with the selected specs should be quite a lot more money, 2080 super, and 32 gb of RAM, 1tb SSD, someone made a mistake there. This is 1,600 and has a 2070 card and half as big of a drive https://www.amazon.com/HP-15-Inch-i7-9750H-Processor-15-dc1047nr/dp/B07SRXV9LG/ref=sr_1_13?dchild=1&fst=as:eek:ff&qid=1594137660&refinements=p_n_feature_five_browse-bin:13580788011&rnid=2257851011&s=pc&sr=1-13
If you can actually buy that at the price, it's worth it. You can always run an external 1440 screen at 120-144hz off that. It should be over $2,000 into the range of 3,000 USD.
Reactions: hepez
