Is Arctic Freezer 7 Pro good for Quad core CPU?
hohyss
25
I see many people are trying to get Q9550.
I am also getting Q9550 but im not sure whether I should
buy Arctic Freezer 7 Pro or buy something else.
it looks like Arctice Freezer 7 Pro works almost perfectly with dual core cpu such as E8400. At newegg, there are some heavy worshipping going on. On the other hand, I can rarely see any quad core users in the reviews.
So how is Arctice Freezer 7 for Q9550 assuming that I am going to overclock it to 3.4? Should I stick with it or should go for more expensive cooler?
The Arctic Freezer 7 is a good budget cooler, but not the best. If you want to get the most out of overclocking your system get a better cooler.
It's a good cooler if you have space constraints, but if you can fit a 120mm fan tower in your case it will be better. The freezer pro 7 will probably accommodate that OC with that processor, but it will definitely be warm. I'd spend just a few more dollars on a xigmatek s1283, or the s963 for a 92mm solution. Those, I think, are the best bang for the buck.
hmm.. I will definately consider those big coolers. But how about Antec 900 case ( heard that it offers very good cooling system ) + arctic freezer 7 pro?
Will it still be worm with antect 900 case's massive cooler?
The main reason why I chose that arctic freezer pro 7 is that it comes with the pre-applied mx-1 thermal paste.
Is there any other good cooler that comes with pre-applied thermal material ? How about those coolers mentioned above? ( s1283, or the s963 )
ACF7P is a good cooler even for overclocking around 3.2GHz using a quad like Q6600.
BTW, ACF7P is applied with either MX-1 or MX-2. I suppose all the new ones are pre-applied with MX-2. I got this info off of Arctic-cooling.com
After consideration, I made a new list.
ZEROtherm Nirvana NV120
http://www.newegg.com/Product/Product.aspx?Item=N82E16835887011
Sumbeam CR-CCTF
http://www.newegg.com/Product/Product.aspx?Item=N82E16835207004
XIGMATEK HDT-S1283
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233003
Thermaltake CL-P0257
http://www.newegg.com/Product/Product.aspx?Item=N82E16835106069
These are the coolers that I have in minds for Ocing Q9550 to 3.4GHz
( 2.8 -> 3.4 )
Aside from the PRICE factor, which one should I get?
