spooky2th :
GhislainG :
It isn't an issue with an Intel motherboard as they are compatible way back to ICH5R.
Seriously??? Are you really saying that el80ne, can pop his RAID configuration from an Asus board into an Asrock board???
Yes if both are Intel based and the chipset has RAID support; that's why he had no problems when moving a RAID 0 to a new motherboard. I wouldn't recommend doing it without a full backup and booting from it could be problematic if upgrading from an older chipset. As an example, moving the RAID from a Z87 motherboard to another Z87 motherboard should work fine and it doesn't matter if the manufacturer is ASRock, Asus, MSI, Gigabyte, etc. The chipset is from Intel, not from the motherboard manufacturer. I presume that would also be true if going from an AMD 99x chipset to the same chipset, but I didn't find that info on their site.
