I am getting ready to begin wiring my house for Gigabit networking (and wireless AC) but am actively looking for the right opportunity to upgrade to 10GBaseT, also. I'm aware of what the standards say about CAT6 and CAT6a (250Mhz vs. 500Mhz). Some CAT6 cables appear to be marked as 550Mhz. I will likely not make a single cable run of more than 75 ft. (22 meters) and 500 ft (152 meters) total for the project so I may not be impacted too much by this. But I only want to pull cables once. My keystones and patch are Cat6a rated as is the wires from patch board to switch.
I would like to know whether the CAT6 550 MHz cable is the same as CAT6a technically. There's a huge price difference between the two and if they are similar enough I'd go for the CAT6 instead (I'm actually not trying to budget, I just want the right thing and if both are equal'ish... ). I'm looking only at 100% copper solid cables for running through the walls.
