[SOLVED] Is Cooler Master - Hyper 212 LED Turbo compatible with TD500L
Feb 20, 2019
16
I just received Cooler Master - Hyper 212 LED Turbo cooler (which is 163mm H), and found the Cooler Maser MasterBox TD500L case (which can fit a max of 165mm H).
Do you think that this cooler will fit the case? Worried that 2mm might make a difference.
Also, if there is an aesthetic part of the cooler that takes up some of the height, I would remove it. I haven't checked it out yet though.
Thanks
