Is Cooler Master Hyper Enough for i5 6600k OC?
GenericUsername71
Commendable
Apr 21, 2016
I will be getting a i5 6600k, along with a gtx 980 ti g1 gaming, so, i im thinking to OC my CPU, To 4-4.2 Ghz, so i wanna know if the this cooler is good enough to mantain my CPU to a reasonable Temperature.
Thank You!
PD: Also i want to know if the EVGA 850 G2 is enough for my system.
Try it and see. It'll also depend on if you have to increase the voltage at all, and some other factors play a role (i.e. case temps). It won't hurt to try. It should be fine for sure, no doubt in my mind.
Yes the 850 G2 is perfectly fine.
