Is Corsair LL RGB fans compatible to use with NZXT HUE+?
Jul 3, 2018
I'm building my first PC here and i have bought the following components:
- NZXT H200i
- NZXT AER RGB 140 mm with HUE+ and Internal USB
I'm interested in Corsair LL120 RGB, am worried that Corsair cable connector might not be suitable on NZXT.
Please advise.
No, you'll need Corsair Lighting Node Pro with Corsair RGB fan LED hub to control LEDs in Corsair LL series fans. Or you can use Corsair Commander Pro as well in place of Lighting Node Pro. Only AER RGB fans are compatible with NZXT HUE+.
RGB LED lighting requires a CORSAIR RGB Fan LED Hub and a CORSAIR Lighting Node PRO. Both are included with all LL Series RGB fan kits, or sold separately. CORSAIR LINK is required for software lighting control.
Lighting Node Pro: https://www.corsair.com/us/en/Categories/Products/CORSAIR-LINK/CORSAIR-Lighting-Node-PRO/p/CL-9011109-WW
Corsair RGB fan LED hub...
Corsair RGB fan LED hub: https://www.corsair.com/eu/en/Categories/Products/Accessories-%7C-Parts/PC-Components/Cooling-And-Corsair-Link/CORSAIR-RGB-Fan-LED-Hub/p/CO-8950020
Commander Pro: https://www.corsair.com/us/en/Categories/Products/CORSAIR-LINK/CORSAIR-Commander-PRO/p/CL-9011110-WW
Here's how the setup would look like:
