That power supply is very low quality. It doesn't matter what computer it's for, I don't recommend it.
I recommend the
Seasonic M12ii 620w Bronze. Don't worry about the fact that it's only Bronze certified, that's an efficiency rating and has nothing to do with product quality. There are plenty of companies that manage to get low quality units certified as high efficiency units, and there are also plenty of companies that produce outstanding quality units but get them certified as a slightly lower efficiency. In my opinion, if it's 80+ efficiency, it's efficient enough... At least until you get to about 1KW or so, then the efficiency really starts to matter in terms of your house wiring.
I really think that the Seasonic M12ii Bronze series of power supplies is the best you can get for under $80.
