Is crossfire possible with a 1 16x pcie and a 1 4x pcie slot?
Yes chipset pcie bandwidth could be affected more than with SLI like you say, but it'd probably not be that noticeable. Is hard to say until trying really. I do agree it'd be better to use a x8/x8 config though to avoid those issues.
Even on a gtx1080 there is little difference between x16 and x4.
You can see some reviews about that.
https://www.techpowerup.com/reviews/NVIDIA/GeForce_GTX_1080_PCI_Express_Scaling/24.html
https://www.techpowerup.com/reviews/NVIDIA/GTX_980_PCI-Express_Scaling/21.html
https://www.techpowerup.com/reviews/AMD/R9_Fury_X_PCI-Express_Scaling/18.html
https://www.techpowerup.com/reviews/Intel/Ivy_Bridge_PCI-Express_Scaling/23.html
I´ve got an Asus Dual RX 480 4gb. I plan on upgrading in the future for a crossfire setup but dont know if my mobo will keep up.
Can you suggest any motherboard capable of crossfire 2 rx 480?
Specifically, no. I'm not that into crossfire or SLI. I would want a board that had at least 2 x8 pci-e slots(or an x16/x8 board).
I find it interesting that there´s only a 3% loss with the Fury X, at 4x 3.0 and somewhat similar with the nVidia cards.
For what the graphs are showing, im assuming there still can be a significant boost in performance with that type of pcie slot?
Ok, thanks, I´ll have a look to see what I can find
Those are only in single GPU configurations, and none of them explore the effect of lanes when in a multi-GPU configuration, which SLI is also in general less susceptible to due to the higher lanes bandwidth and the extra SLI link, while Crossfire is done entirely across the PCI-E lanes, which x4 could adversely affect the performance as it is used more.
