Is cs550m enough for this build ? If yes , which one should I choose between cooler master g550m and corsair cs550m
Greenp4nd4
Commendable
Oct 29, 2016
23
Intel core i5 7500 kaby lake 3.4 ghz
Msi b250m bazooka socket 1151
Asus gtx 1060 strix OC
SSD 120gb Kingston UV400 ( maybe in time I'll add one more )
WD Blue 1 tb 7200 rpm ( maybe In time I'll add one more )
16gb hyperx fury black ddr4 2133mhz
All in zalman z11 neo
its OK and it comes under Tier Three, and it is gold certified so that will do with your rig
I recommended Seasonic cuz they make one of the best quality PSU
and if possible get a H series motherboard like H270 from brands like MSI / Asrock / Gigabyte /EVGA etc
No big difference, just some input or output ports and may be couple of features, that's the only difference.
if your using this system for just regular use like internet, gaming so its fine go with it
