Is CX650M enough for my build
Merp97
18
My build is going to be,
i7 7700k (May Overclock later)
GTX 1060 6GB
16GB RAM(8*2) @2666MHZ
ASUS ROG STRIX Z270F MOTHERBOARD
1TB @7200RPM
120GB SSD
COOLER MASTER HYPER 212X
3 MORE CABINET FANS 120MM
Will this 650w PSU be good or should i upgrade or downgrade ?
And also is this CPU cooler Hyper 212X enough for the i7 7700k or should i install Liquid Cooling ?
Thanks in advance !!
I am on a tight budget here if you would suggest a more cheaper PSU what would you recommend and can the hyper 212x handle overclocking ?
Latest posts
