Is D-Sub a Input or an Output
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
So the situation is, i'm trying to use my monitor as a ps3 display. I was gonna use this http://tinyurl.com/o7s4w4n problem was i made another form saying what i need. She/He said i need a output. So i looked at my monitor and it says 'D-Sub'. Is it in or out?
The monitor has a port for the cable, you'll need a cable to connect it to PS3. The console needs composite to VGA adaptor for D-Sub ports. The port on monitor is for input, the port on PS3 is output, and the cable is the transmitter. The cable you chose is fine for the purpose.
Wait isn't the PS3 the input?
