I am using a power button from Amazon which has screws to connect the PC front panel connectors from the motherboard to the button. I have stripped some of the wires from the switch that turns the PC on since I don't want to use it. I can easily connect the other button but I am worried that the uncovered wires might short or something. I don't have any heat shrink wrap but I was wondering if electrical tape or just tape in general would work? If I use electrical tape would I have to use a lighter on it or can I just wrap the tape around the wires? Are they fine on their own as long as no one touches them?
